I am using Markdown with HTML in text panel.
Is it possible to use ‘system’ text color in HTML, so as it has the same behaviour (i.e. it was light when dark theme is chosen and dark when the light one is chosen)?
For example, what should be used instead of lightgray in the example below:
###### Links
<a href="/d/db-id/db-1" style="color: lightgray;">Dashboard Title</a>
I would like to use this color:
