Hi Grafana Community,
I’m currently using the Boom Theme panel , which I understand is deprecated as of Grafana version 11.6. This panel was very useful for me because it allowed HTML and custom CSS for theming purposes. Specifically, I used it to dynamically change the background color and font of other panel headers based on custom logic.
Here is a snippet of the CSS I use:.panel-title-container[data-testid=‘data-testid Panel header NOM DOMAINE’] {
background-color: rgb(31, 96, 196);
color: rgb(225, 235, 235);
This customization is essential in my dashboard for visual grouping and clarity.
Attached is a screenshot showing how I configured this within the Boom Theme panel.
Is there any recommended alternative or workaround in Grafana 11.6+ that would allow me to achieve similar visual theming across panels?
Ideally, I’m looking for a solution that allows injecting or applying CSS conditionally or globally based on panel titles or tags.
Thanks in advance for your help!
