I’m not sure what is causing this but I thought it was InfluxDB updating itself to the latest version (image: “influxdb:latest”) as it runs as a docker corrupting things.
I have a telegraf.conf file that is using SNMP to import data into InfluxDB and it’s been fine for about a year now with regular Ubuntu updates.
Today I ran apt-get update and 1 very important dashboard stops working and no data is fed into InfluxDB if I check inside the database.
Luckily I have a snapshot I can revert to test.I’m not sure which one of these updates is causing it, but I’d guess it is the first line which is Docker:
sudo apt-get update
Hit:1 https://download.docker.com/linux/ubuntu focal InRelease
Hit:2 https://repos.influxdata.com/ubuntu focal InRelease
Hit:3 http://gb.archive.ubuntu.com/ubuntu focal InRelease
Hit:4 http://gb.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:5 http://gb.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:6 http://gb.archive.ubuntu.com/ubuntu focal-security InRelease
Reading package lists... Done
This is my docker compose file, pretty standard:
This is my telegraf config file that pulls information from 100s of devices, this one is pointing to just 1 devices for testing.
This is what it should look like, after the upgrade it says no data.
What could it be and what do you think I could try next?
Thanks
