latest version in unRaid docker -
I am looking to achieve Energy monitoring using the Home Assistant data & monitor my Unraid server. -
I have installed docker containers for InfuxDB , Grafana & Telegraf -
What happened?
using Query i get No Data -
have you configured the influxdb data source plugin in grafana? It is one of the core data sources that is built-in.
what version of grafana are you running?
also this might be a more useful forum if you are running unraid and they are packaging Grafana into something larger:
Thank you for reply, Regarding Grafana version , I am running the latest version from July. I am able to obtain a graph in Ibfluxdb but not Grafana. I cannot copy the influxdb script into grafana as it does not work on my MacOS. I am typing the script but have these errors all the time which i don’t know how to read or fix them. Error invalid: compilation failed: error @2:4-2:66: expected comma in property list, got COLON error @2:47-2:65: missing property key" here is my typed script.
from(bucket: “nodered”)
|> range(start: 2022-07-07T09:55:34.539Z. stop: v. timeRnageStop)
|> filter(fn: (r) => r[“_measurement”] == shellies/shellyem-485519C99C50/emeter/0/total" or r[“_measurement”] == shellies/shellyem-485519C9BD88/emeter/0/total")
|> filter(fn: (r) => r[“_field”] ==“value”)
|> aggregateWindow(every: 30s, fn: mean, createEmpty: false)
|> yield(name: “mean”)
if you are able to advise where i am going wrong it would be appreciated
you need to configure the datasource plugin first:
