Grafana 7.5.0
rasperry pi 4 -
show data from a influx DB -
try different plugins without any success -
What happened?
no data -
show the collected data -
You’ve shown us the raw data which is being inserted into InfluxDB.
It would be more useful to see the data which you get out of InfluxDB, because
that’s what Grafana needs to do.
Please copy and paste an Influx query and its results, for the same data you
gave earlier.
Antony.
