I am using Grafana version Grafana v11.1.0-71516 (0ba54152dc) on Grafana Cloud.
I am trying to update the recipients of an existing report via the Grafana API.
I am using a Python script to send a PUT request to the Grafana API to update the recipients list of an existing report.
What happened?
I received a 400 Bad Request error, with the message {"message":"bad request data","traceID":"56283328ae5542906f90204f11bdc710"}
I expected the recipients list of the report to be updated successfully, adding the new recipient to the existing list.
Here is my Python code:
import requests
import json
grafana_url = 'http://***********.grafana.net/api/reports/11'
api_key = '***************' # Generated via service account at the instance level
# Headers
headers = {
'Authorization': f'Bearer {api_key}',
'Content-Type': 'application/json'
# Fetch the existing report configuration
response = requests.get(grafana_url, headers=headers)
if response.status_code != 200:
print(f'Failed to fetch report: {response.status_code}, {response.text}')
exit()
# Update the recipients list
report_config = response.json()
report_config['recipients'] = report_config['recipients'] + ', newrecipient@example.com'
# Send the PUT request to update the report configuration
response = requests.put(grafana_url, headers=headers, json=report_config)
if response.status_code == 200:
print('Recipient added successfully.')
print(response.text)
else:
print(f'Failed to add recipient: {response.status_code}, {response.text}')
This is the response I received:
Failed to add recipient: 400, {"message":"bad request data","traceID":"56283328ae5542906f90204f11bdc710"}
No errors were received in the Grafana UI. The error message received from the API response is: {"message":"bad request data","traceID":"56283328ae5542906f90204f11bdc710"}
Yes, I followed the instructions on the Grafana documentation page for updating reports via the API: Reporting API | Grafana documentation. Unfortunately, I think this documentation has an error, the example it gives for updating the data uses GET, when the description it gives suggests using PUT.
Thank you for your help!
