Grafana Update Datasource
    V8.3.5
    Trying to make a PUT request to update the existing grafana datasource with UID and the json file in GO.
    put_req, reqerr := http.NewRequest(“PUT”, fmt.Sprintf(“%s/api/datasources/%s”, GRAFANA_URL,uid), bytes.NewBuffer(jsonBytes))
  • What happened?
    Got the response and couldnot update the datasource
    response:
    {“message”:“Datasource has already been updated by someone else. Please reload and try again”}
    To update the datasource.
    Structure defining the datasource:
    type ESDataSource struct {
    UID string json:"uid"
    Name string json:"name"
    Type string json:"type"
    URL string json:"url"
    Access string json:"access"
    Database string json:"database"
    JsonData ESDataSourceJsonData json:"jsonData"
Has anyone solved this? I’m having the same issue.
I’ve posted a solution here: How to "reload datasource" without restarting server
