Hi Grafana Team!
I have a datasource which is provisioned using a file.
The file looks like below,
apiVersion: 1
datasources:
- name: Druid
version: 1
type: grafadruid-druid-datasource
access: proxy
orgId: 1
uid: _Pvp4QWYS
isDefault: true
jsonData:
connection.basicAuth : true
connection.url: mu_url
connection.basicAuthUser: my_user
secureJsonData:
connection.basicAuthPassword: my_password
editable: false
enabled: true
Everything is working fine.
Now, I want to rename this datasource to Druid - Events, so I made the following changes,
datasources:
- name: Druid - Events
version: 2
However, now when I restart Grafana with the updated file, I get this error,
logger=provisioning.datasources t=2023-01-30T12:42:56.376372465Z level=info msg="inserting datasource from configuration " name="Druid - Events" uid=_Pvp4QWYS
logger=provisioning t=2023-01-30T12:42:56.398055752Z level=error msg="Failed to provision data sources" error="Datasource provisioning error: data source with the same uid already exists"
I looks like Grafana is trying to insert a new Datasource rather than updating the existing one.
Can someone help me out here please? How do I make Grafana update the same datasource rather than make it create another one?
I am on Grafana v9.3.6 -
Trying to update the name of a datasource which was provisioned using a file. -
By updating the provisioning file -
What happened?
Grafana fails to start with the following error,
Grafana should rename the datasource -
See above -
See above -
Followed instructions from here: Provision Grafana | Grafana documentation
