Facing issue wrt mysql datasource :
configuration:
apiVersion: 1
datasources:
- name: Prometheus
type: prometheus
access: proxy
url: "http://localhost:9090/prometheus-production"
- name: Loki
type: loki
access: proxy
jsonData:
maxLines: 1000
url: "http://localhost:3100"
- name: abc
type: mysql
url: x.x.x.x:3306
uid: P5B83B323F800A6FD
user: grafanareader
jsonData:
maxOpenConns: 3
maxIdleConns: 3
maxIdleConnsAuto: true
connMaxLifetime: 180
secureJsonData:
password: xxxx
- name: def
type: mysql
url: x.x.x.x:3306
user: grafanareader
jsonData:
maxOpenConns: 3
maxIdleConns: 3
secureJsonData:
password: xxx
error:
May 10 14:39:46 ip-172-31-62-33 grafana[117751]: logger=provisioning t=2024-05-10T14:39:46.759790681Z level=error msg="Failed to provision data sources" error="Datasource provisioning error: data source with the same uid already exists"
May 10 14:39:46 ip-172-31-62-33 grafana[117751]: Error: ✗ not healthy, 0 terminated, 1 failed: [invalid service state:
Failed, expected: Running, failure: Datasource provisioning error: data source with the same uid already exists]
When i define a UID on datasource name def it works or else grafana fails with the error. Let me know what am i doing wrong. the UID on abc datasource is newly defined earlier it was present without a UID
