The errors we see here is for 2 Datasources named Loki and Prometheus. Both the datasources are not being used by us. We planned to delete the data sources but they are currently in read-only state and cannot be deleted from UI.
Data Sources:
I have checked values.yaml file used for Grafana deployment and the value for sidecar.datasources is set to false. So ideally, it shouldn’t add a new data source.
It seems the data source was added in previous release and was not removed automatically. May be some reference of it is stuck in sqlite3 database which is a default DB of Grafana.
Is there a way to remove these default datasources?
