The settings of the datasources in the UI are not saved when using provisioning after restarting Grafana
    Grafana version: 10.1
    OS : Ubuntu (grafana in docker)
    Saving the datasource settings in the UI without overwriting the settings from the provisioning file when restarting Grafana
    In the provisioning folder, I added a yaml file with the settings of the datasources (with the ability to edit in the UI). In the UI, I made changes to the datasource and saved it, then restarted the Grafana docker container
  • What happened?
    All the changes made through the UI are gone. That is, the settings from yaml from provisioning were applied again. Changing the configuration version does not help, I tried to reduce and increase the version
    When using the datasource settings from provisioning, changes in the UI were saved.
    Here is my sample settings file for provisioning
-   name: rx-log-metrics
    editable: true
    type: elasticsearch
    access: proxy
    url: 'http://192.168.55.28:9200'
    jsonData:
        timeField: "@timestamp"
        esVersion: 7.16.1
        index: "rx-log-metrics*"
        logMessageField: message
        logLevelField: logLevel
    version: 11
    No
    Used this documentation Provision Grafana | Grafana documentation
Tell me, please, how do I make my case?
welcome @pavelmokrushin
try to add the following line under volumes: in your docker-compose file.
 - ./grafana-db/:/var/lib/grafana # persist Grafana database
Then, create a new directory where your docker-compose file is. The name of the new directory must match the name of the directory in the docker-compose file.
mkdir ./grafana-db
Change file ownership, so the docker container can read the contents of the folder as well as write to it
chown 472:root ./grafana-db/
Finally, compose the container as root
sudo docker compose up -d
Hope it helps!
I have volume configured for Grafana in docker. The problem is not that the database is being deleted, but that data from the provisioning datasource file is being overwritten in it, and I can’t influence it in any way
hi @pavelmokrushin
Thanks for the clarification
I tried from my end and I got the same results.
You are welcome to open a new issue in our public repo and link back to this post
Thank you, I will write there
Hi, I’ve run into the same problem. Did you create a Github issue? If so, can you post a link to it? I cannot find it.
hi, here is the link Provision: The settings of the datasources in the UI are not saved · Issue #75722 · grafana/grafana · GitHub
They solved this problem there, and it started working for me after the correction.
Thank you for the quick reply. Reading the comments I realized that I have to add a version field in order to store changes between container restarts. It works now!
