Grafana HTTP API is not updating the dashboard correctly
I am trying to update existing json file using HTTP grafana API but it is not updating the dashboard successfully in grafana, i used the below command,
curl --user admin:admin -vvv "http://local:3000/api/dashboards/db" -X POST -d @My_Metrics.json -H 'Content-Type: application/json'
I got the response message for the above command is,
  • About to connect() to localhost port 3000 (#0)
  • Trying 10.x.x.x…
  • Connected to localhost (10.x.x.x) port 3000 (#0)
  • Server auth using Basic with user ‘admin’
POST /api/dashboards/db HTTP/1.1
Authorization: Basic YWRtaW46YWRtaW4=
User-Agent: curl/7.29.0
Host: community.grafana.com
Accept: /
Content-Length: 39380
Expect: 100-continue
HTTP/1.1 100 Continue
HTTP/1.1 422 Unprocessable Entity
Cache-Control: no-cache
Content-Type: application/json; charset=utf-8
Expires: -1
Pragma: no-cache
X-Frame-Options: deny
X-Xss-Protection: 1; mode=block
Date: Wed, 03 Jul 2019 12:19:20 GMT
Content-Length: 84
  • HTTP error before end of send, stop sending
  • Closing connection 0
[{“fieldNames”:[“Dashboard”],“classification”:“RequiredError”,“message”:“Required”}]
Kindly assist where is the problem and how to resolve this
