Hello! I need help with Dashboard API.
I trying to edit my dashboards with api , but get error response “{‘message’: ‘Not found’}” after try to put my updated json to Grafana.
I compare two jsons, received from server and edited, its identical. Maybe I do something wrong?
My request string is
requests.post(url_str, data=json.dumps({“Dashboard”: dsh_json_updated}), headers=base_header)
If it need, i can show full script.
Yes I believe more information would help us a lot. Have you had any success communicating with the API manually using an http client like cURL?
Yes, I have full access to api, i get all jsons of my dashboards with right ids.
But when i change some dashboard manually and try to start my script - it works fine. Its like strange internal issue that i cant describe.
hmmm, sounds like your script might be doing something funky…
One condition where this happens is when the folder where one is trying to create the dashboard does not exist.
