Up and down bar chart
How can I do such a up and down bar chart with grafana -
The up/down style happens automatically without any special customization when the numbers in your dataset are negative; this draws the bars below the origin line.
You can see examples of bar charts here, if you log in you can edit one as a sample and play with it, see how it changes; add a negative value field and it will happen automatically:
https://play.grafana.org/d/ktMs4D6Mk
just normal stacking on a barchart should do it
Welcome @evgeniiml
So are those negative values at the bottom or categories
if you want to show positive numbers but below the line, you can use an override to make them negative without showing the minus:
