Unable to test SMTP alerts from send test notification configuration, getting level=error msg="Missing receiver"
I am using the latest version of Grafana, unable ti use the latest Altertmanager from Grafana.
Trying to test the Contact Points in Alerting feature but getting the following.
logger=ngalert.notifier.email t=2023-05-29T11:49:39.761180109Z level=error msg=“Missing receiver”
logger=ngalert.notifier.email t=2023-05-29T11:49:39.76128092Z level=error msg=“Missing group labels”
Hello, Yeah I was facing the same issue after upgrade grafana to 9.5.
did you figure it out how to fix it ?
Have youblooked at docu about smtp
hello,Have you solved your problem?
