Unable to sort table legend on name or values
    8.0.1 on Google GKE
    I want to be able to (manually) sort the legend on either name, or max/mean values
    I configured the legend to be a table and I try to click on the min/max headers (the metric names column does not have a header, so not clickable)
  • What happened?
    Nothing happens when I click the min or max header in the legend
I expected the legend to be sorted. I know it worked in older versions of Grafana (5.x) that I can remember.
Am I forgetting any setting for sorting to be enabled ? This is a panel containing data from a BigQuery query.
screenshot
confirmed, time series - legend table cant be sorted
so, meanwhile, workaround is back to using Graph (old) …?
legend is still sort-able in Graph (old)
*not sure if this is considered as a bug for v8 (time series graph) or not…
Cool, thanks for this workaround. After switching to “Graph (old)” we can now sort again.
Is there a reason why it wouldnt work with Timeseries dashboard. I dont like moving back and forth
Not developed yet in time series graph I assume.
+1 for this feature. it is really blocking for using new time series graph.
+1 for this feature, blocks migration to the new time-series panel.
+1 this feature, pretty pls :slight_smile:
+1 for this feature ! Last need to migrate to this new panel
+1 here too. How was such a basic function ignored.
+1 this is really important for my dashboards.
+1 for new graph panel to support table sorting like old graph panel.
+10 this feature is really needed
I just registered to post this:
+1 me too.
+1
I love the new Time Series panel, but my users keep getting stuck on the inability to sort the legend.
+1
much needed feature, it`s that hard to implement?
I’m waiting for this feature too
Any updates? JIRA for that?
This issue prevents us from using new Time Series panel as we need sort feature.
On the other hand, Annotations not working propely, once you switch from Graph to Time Series and vice versa
Think they have Time Series: Change legend order · Issue #30907 · grafana/grafana · GitHub for this, though it’s closed now
