+1
when can the function be expected
Is it possible to raise the priority on this one? Sorting legend is one of the critical features of the Graph panel.
+1
FYI, it looks like issue has been closed without resolution⦠here is link to github
can someone from grafana community advice if it should be reopen or new one created?
Hey there,
I would this feature to be implemented as well.
In addition to that, I would like to be able to sort the legend based on another field, like the use case bellow, which is presenting the execution of the steps of a workflow. Ideally those steps should be ordered based on the execution sequence, not on their names.
Have you had that kind of request already?
Thank you
PR is merged. Will be part of the next release, Grafana 8.3. https://github.com/grafana/grafana/pull/40226
@simonverzijl
