Grafana v11.1.3 Windows 10
Im Trying to sort the Legend of my newly create Dashboard -
I tried searching for possible edits to my query and tried several data transforms -
What happened?
What do you mean what happened it didnt work -
i expected it to work
This is my query so far: ifHighSpeed{instance=“192.168.8.250”} unless (ifIndex>=1000000 or ifIndex==1057) i didnt find any option to resort the IfName to match the order i need.
It sorts it like this 1:1,1:10,1:11 i want it to sort it like this 1:1,1:2,1:3,1:4…
No Logs or errors
Same Problem as this topic:
Those are string values, so grafana is sorting them correctly. to sort it properly you will need to convert those values to maybe numeric
see this examlpe using ms sql
;with src
as
--1:1,1:2,1:3,1:4
select '1:1' as zoo union
select '1:10' union
select '1:11' union
select '1:2' union
select '1:3' union
select '1:4'
select zoo ,
cast(replace(zoo, ':','.') as decimal(10,2)) as zaa
From src
order by 2
--order by 1 --1:1, 1:10, 1:11, 1:2, 1:3, 1:4
--order by 2 --1.10, 1.10, 1.11, 1.20, 1.30, 1.40
i forgot to add i am using Prometheus/PromQL. is it possible to order by in PromQL? I tried using sort and tried sort_by_label but if i use sort_by_label i get the error
Error executing query: invalid parameter “query”: 1:1: parse error: function “sort_by_label” is not enabled
How do i convert them into Numeric in Prometheus or Grafana?
im using prometheus/snmp_exporter as a data source.
How do i convert those into Numeric Values on Grafana/snmp_exporter?
Are those values always 1:< number >? Or can it be < number >:< number >?
If the first, you can strip the 1: using (I think) grafana transformation, then convert it to number and sort by that. If that doesn’t work (or the second scenario) then, deep breath
You can use prometheus function label_replace to split those “numbers” into two different labels (considering there are alwyas two):
label_replace(label_replace(your query, "major", "$1", "your current label", "(.*):(.*)"), "minor", "$2", "(.*):(.*)")
after that your query should have two more labels (major i minor), then in grafana transformations you convert the type to number (possibly using some kind of sort transformation after). I’m not sure it’ll work out of the box though.
