How to sort the legend?
    11.0.0
    I´d like to sort my legend on custom behaviours e.g. ERROR, WARN, INFO instead of INFO,ERROR,WARN
    I tried to use the Legend-Options but there is no sorting available.
Also i tried to use the transformation with the option sort, but this also didn´t gave me the solution
  • What happened?
    Sort the legends on custom behaviours or at least descending, ascendig and not randomly
Legends are sorted in descending order based on their value. In your example,
info - 42%
error - 39%
warn - 19%
That’s the reason legends are shown this way. if the value of these changes, the legend’s order will also change.
is there any way to modify the order of items in the legend?
use sort by transformation or organized field by name and arrange according to you like error then warn then info…arrange it.
