Hover tooltip / legend sorting for new time series panel
Screen Shot 2021-11-23 at 3.43.44 PM
This is no longer available for the new time series panel. How can we sort legends and/or the hover tooltip?
We get these options now, which are useful, but is it possible to sort values now?
Screen Shot 2021-11-23 at 3.54.13 PM
welcome to the :grafana: forum, @miketwenty1
see these related issues and chime in where you see fit:
This is driving me nuts too!
Specifically not being able to sort DESC in Tooltip mode All, oof!
Any new suggestions/changes since November?
ToolTip is not the same as the Legend.
What about when the Legend is hidden?
Even if the Legend is shown as a table, changing the sort order of the legend has no effect on the tooltip.
Not being able to sort the tooltip makes it a real issue for graphs that have no legend.
Until this is resolved on the Time Series panel, I will be using the old Graph panel as a solution.
However, what makes me angry is the comment when you switch from Time Series to old Graph:
Consider switching to the Time series visualization type. It is a more capable and performant version of this panel.
I have not found it to be “more capable” when it is lacking the ability to sort the tooltip (both ascending and descending sorts are needed – I have graphs that show all negative numbers that I need the tooltip sorted in ascending order while I have other graphs that need the tooltip sorted in descending order).
hi @devinteske
I believe this feature was re-added in 8.4.0
try this time-series panel on our sandbox or try upgrading and see if it behaves like before? Hoping this gets you unblocked :+1:
