When i give more than 1 dashboard tag in Links to get the list of dashboards in dropdown , then i dont get any dashboards in dropdown .
Please help
Hi @svenkatrav0408,
What version of Grafana are you running?
Do you think you could try and reproduce this on play.grafana.com?
Hello @anon70503803 ,
the version is " v7.5.5 (b5190ee547)"
yes i can reproduce this on play.grafana.com
@svenkatrav0408 is this issue resolved for you?
I am facing the same issue. Not able to view tags in the dropdown. I am using Version V8.0.7
