Dashboard links help
I was under the impression that dashboard links worked in this manner:
Then I would be able to click on “Other Dashboards” link and a dropdown would show with a choice for dashboard1, 2 and 3 but when I click on it, nothing shows.
Not quite - it works based on tags rather than dashboard names.
First assign a particular tag (e.g. “dropdown”) to each of the dashboards that you want to show up in that dropdown. Then on the dashboard where you want the links, in that “With tags” field, enter the name of that tag you just assigned.
Hope that helps.
Works perfectly! Thank you!
