Link specific dashboards on another dashboard
I tried to link multiple dashboards with the help of Links. It normally loads all the dashboards, but not specific ones.
I want to link two specific dashboards. First I assign tags to the individual dashboard.
and, link one dashboard it works.
but when I tried with multiple tags it didn’t work. guide me on this
Hi @gerardlj,
Thanks for opening this post. What grafana version are you using? and was this problem appear after a recent update/upgrade
If nothing was changed. Then can you please try to reproduce this on https://play.grafana.com/
Thanks
