Tabs in Dashboards
I want to create multiple tabs in a single dashboard in Grafana. Can someone please suggest how can I achieve this ?
My opinion is to create multiple dashboards with some series of tags and add dropdown links to those dashboars.
Currently, that’s exactly how I have implemented ( by creating same tag to multiple dashboards and created dropdown link that displays all dashboards with a specific tag )…
wanted to check If there is any Built in solution from Grafana , rather than a workaround !
Hey! Did anyone find any other solution for creating tabs in one dashboard?
