Tabs to organize visualization
  • v9.5.1, Windows 10 Ent
    Organize different visualizations using tabs, currently “rows” is the only apparent way of doing it but you have to close other rows to keep one row visible. In case of tabs, only the ‘current’ tab would be visible.
    Not able to achieve “Tabs” format / organization.
    Feature not available
Hi @tariqg,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
Yes, currently we have support for the rows to organize the panels. But using tabs could also make the experience better.
This definitely sounds like a feature request and for that, the best place is to use our GitHub Discussions where you can open it using this link.
Define your use case (like you had defined here) and try to provide as much detail as possible to get more upvotes and attention from the community and the engineers.
Once you created the request, paste here the link so that we can also add more detail into it.
I hope this helps.
There as been many request for the same for many years, still there is a demand for this feature @usman.ahmad
kindly have look on this Git request
