Hi all,
I’m currently developing a Grafana App Plugin with a UI extension that adds a custom link to the Dashboard Panel Menu. It works as expected in Grafana version 11.5.0 and above, but does not appear at all in versions 11.4.0 and below.
According to the Grafana documentation, UI extensions (specifically grafana/dashboard/panel/menu targets) should be supported starting from version 11.1.0, so I was expecting this to work in 11.1–11.4 too.
Here’s a simplified version of my setup:
plugin.json
"type": "app",
"id": "test-testing-app",
"name": "Testing",
"info": {
"version": "%VERSION%",
"updated": "%TODAY%"
"dependencies": {
"grafanaDependency": ">=11.1.0",
"plugins": []
"extensions": {
"addedLinks": [
"targets": ["grafana/dashboard/panel/menu"],
"extensionPointId": "grafana/dashboard/panel/menu",
"type": "link",
"title": "Test UI Extension",
"description": "Test description"
My module.tsx (Plugin Entry)
import { AppPlugin, PluginExtensionPoints } from '@grafana/data';
import { Button, Modal } from '@grafana/ui';
export const plugin = new AppPlugin()
.addLink({
targets: [PluginExtensionPoints.DashboardPanelMenu],
title: 'Test UI Extension',
description: 'Test description',
onClick: (event, { openModal }) =>
openModal({
title: 'My Modal',
width: 500,
height: 500,
body: ({ onDismiss }) => (
<div>
<p>This is our Test modal.</p>
<Modal.ButtonRow>
<Button variant="secondary" fill="outline" onClick={onDismiss}>Cancel</Button>
<Button onClick={onDismiss}>OK</Button>
</Modal.ButtonRow>
</div>
Here is the screenshot of my plugin extension in v11.5.0
Here is the screenshot of my plugin extension in v11.2.0
My Questions:
- Is there a known breaking change or bug in Grafana versions 11.1.0–11.4.0 that prevents
grafana/dashboard/panel/menuUI extensions from rendering? - Are there any additional flags or plugin settings required in lower versions for these links to appear?
- Can anyone from the Grafana team or community confirm the actual working version range for
PluginExtensionPoints.DashboardPanelMenusupport?
