Grafana v10.4.2 (22809dea50)
Ubuntu 22.04.4 LTS -
I’m trying to save changes to a dashboard -
By making a change, any change, then clicking on the save dashboard button.
Notes: I am the only user, only admin, this is a brand new install with no customizations, it is a very simple test dashboard with only a few elements. -
What happened?
I get an error that just says “Failed to fetch”
Yet in the syslog there is a “level=info msg=“Request Completed” method=POST path=/api/dashboards/db” for the event.
I cannot navigate away from the dashboard without discarding the changes because it won’t save, this of course rolls everything back.
Yet if I close the browser, dismiss the warning about leaving unsaved changes, then reopen a new instance of the browser. I see that the changes actually are saving, it’s just not being recognized.
I expect to be able to save a dashboard without hard closing the browser.
Any advice would be appreciated.
