Grafana is running behind reverse proxy. Recently we switched our runtime stack from podman to (single node) k3s and thus the reverse proxy from nginx to traefik. TLS is enabled on Traefik Ingress, but not on grafana (Traefik always does TLS termination).
We have dashboards with Alert list panels. The Alert list panel gets it’s data from a prometheus datasource. When we were using nginx as reverse proxy, the alert list got updated immediately as soon as any alert changed.
With Traefik as reverse proxy the auto updating of the Alert list panels does not work any more.
In the logs I find many entries like this:
{"duration":"10.457473ms","handler":"/api/live/ws","level":"info","logger":"context","method":"GET","msg":"Request Completed","orgId":1,"path":"/api/live/ws","referer":"","remote_addr":"A.B.C.D","size":0,"status":-1,"t":"2023-08-18T13:15:41.561089762Z","time_ms":10,"uname":"XXX","userId":1}
The remote_addr is the actual address of my laptop, but the status -1 looks a bit suspicous to me.
The Traefik IngressRoute for grafana is configured like this:
apiVersion: traefik.containo.us/v1alpha1
kind: IngressRoute
metadata:
labels:
app: grafana
spec:
entryPoints:
- websecure
routes:
- kind: Rule
match: Host(`grafana.my.domain.com`)
services:
- name: grafana
port: 80
What I think (please correct me if wrong):
- for immediate update in the Alert list panels Grafana live API is used
- Grafana live API uses
/api/live/wsendpoint which uses websockets - websockets get broken due to TLS termination by traefik
status: -1in Grafana logs comes from not working websocket connection
What I tried as well:
- use
IngressRouteTCPinstead ofIngressRouteand enable TLS passthrough.- The
X-Forwarded-*headers are not there anymore and thusremote_addrin the logs is changed to the IP of traefik pod. statusis still-1
- The
- Run Grafana with TLS enabled, configure
IngressRouteto usescheme: httpsand use aServesTransportin Traefik to access grafana with TLS enabled.- Grafana is accessible as when not running with TLS enabled
- still TLS is terminated at ingress
- still
statusis-1
Is there a configuration I missed to get immediate live update working through traefik in k3s?
