Grafana version
Grafana v10.0.3 (eb8dd72637)
with docker -
trying to achieve
I want use grafana with loki live stream log feature
grafana is behind nginx (reverse proxy) and ssl on -
How trying to achieve it?
I reference doc
Run Grafana behind a reverse proxy | Grafana Labs
and enable ssl on nginx -
What happened?
when ssl not enable
grafana with loki live stream log can work
when I enable ssl
loki live stream log stop working
and I get log in loki
msg="Error in upgrading websocket" err="websocket: the client is not using the websocket protocol: 'websocket' token not found in 'Upgrade' header"
nginx config
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream grafana {
server grafana-1:3000 max_fails=1 fail_timeout=1s;
server grafana-2:3000 max_fails=1 fail_timeout=1s backup ;
server {
listen 3000 ssl;
ssl_certificate /etc/letsencrypt/live/${HOST_FQDN}/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/${HOST_FQDN}/privkey.pem;
error_page 497 301 =307 https://$host:$server_port$request_uri;
proxy_connect_timeout 10m;
proxy_send_timeout 10m;
proxy_read_timeout 10m;
location / {
proxy_set_header Host $http_host;
proxy_pass http://grafana;
location /api/live/ {
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
how do I update config to accomplish this ?
thanks
