Hey there!
I’m running Grafana 8.1.2 behind a nginx reverse proxy, configured as shown here.
The website is working correctly, I can create users, add panels, dashboards, data sources, etc, but if I try to go on any dashboard, I get those errors in the top right corner:
Templating [job]
Error updating options: Cannot read property 'result' of undefined
Templating [instance]
Templating [world]
and when I check the console to see what’s happening, I get this error WebSocket connection to 'wss://website.tld/api/live/ws' failed.
If I check my Grafana server logs, I see this error:
t=2021-08-21T13:36:47+0200 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=//ws status=404 remote_addr=IP time_ms=2 size=33010 referer=
Here are my configurations:
- Grafana:
[server]
# The ip address to bind to, empty will bind to all interfaces
http_addr = localhost
# The public facing domain name used to access grafana from a browser
domain = website.tld
- Nginx:
# this is required to proxy Grafana Live WebSocket connections.
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
server {
server_name website.tld;
root /usr/share/nginx/html;
index index.html index.htm;
location / {
proxy_pass http://grafana.staged-by-discourse.com/;
# Proxy Grafana Live WebSocket connections.
location /api/live {
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_set_header Host $http_host;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/website.tld/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/website.tld/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = website.tld) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
return 404; # managed by Certbot
How can I fix this problem?
