System setup
Debian 11 bullseye
Grafana 11.1.0
Apache 2.4.59
I am using Apache as a reverse proxy for Grafana. It is served from a sub-path.
Problem
I keep getting a WebSocket connection failure in the Browser console.
The Grafana logs look like this:
Jul 03 11:21:48 ... grafana[6215]: logger=context userId=... level=info msg="Request Completed" method=GET path=/api/live/ws status=400 remote_addr=... referer= handler=/api/live/ws status_source=server
The Apache logs look like this:
127.0.0.1:443 192.168.52.2 - ... [03/Jul/2024:11:24:55 +0200] "GET /grafana/api/live/ws HTTP/1.1" 400 416 "-" "<user agent info>"
Config
I know that the reverse proxy needs to be configured properly to pass along the WebSockets connection, but I can’t get it to work.
Here what I attempted in my Apache configuration:
<IfModule mod_ssl.c>
<VirtualHost *:443>
SSLCertificateFile ....pem
SSLCertificateKeyFile ....key
Header always set Strict-Transport-Security "max-age=31536000; includeSubDomains"
SSLProtocol all -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
SSLHonorCipherOrder on
SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
SSLCompression off
SSLOptions +StrictRequire
SSLProxyEngine on
SSLProxyCheckPeerCN off
<Proxy https://localhost:3000>
AuthType Basic
AuthName "..."
AuthBasicProvider ldap
AuthLDAPUrl ldaps://...
AuthGroupFile "/etc/.htaccess.groups"
Require group GRAFANA
RewriteEngine On
RewriteRule .* - [E=PROXY_USER:%{LA-U:REMOTE_USER},NS]
RequestHeader set X-WEBAUTH-USER "%{PROXY_USER}e"
</Proxy>
# This is my attempt to handle the WebSockets requests:
RewriteEngine On
RewriteCond %{HTTP:Connection} upgrade [NC]
RewriteCond %{HTTP:Upgrade} websocket [NC]
RewriteRule /grafana/(.*) ws://localhost:3000/grafana/$1 [P,L]
ProxyPass /grafana https://localhost:3000/grafana
ProxyPassReverse /grafana https://localhost:3000/grafana
<Location /grafana>
RequestHeader unset Authorization
</Location>
</VirtualHost>
</IfModule>
The grafana.ini should be configured properly. Here is the server section:
[server]
protocol = https
http_addr = 127.0.0.1
http_port = 3000
domain = ...
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
serve_from_sub_path = true
cert_file = ....pem
cert_key = ....key
Please let me know, if I should provide any other information.
