Need help for configuration with apache2 subdomain and subpath
  • Ubuntu 20.04.6 LTS
  • Grafana : 10.2.0
Note : _ are add in “url”
    I try to setup grafana on a specific web (working) configuration on apache :
https_://sub.domain.com/ => an index page
https_://sub.domain.com/subpath1 => grafana
https_://sub.domain.com/subpath2 => other stuff
With tls redirection & websocket working.
And be sure my conf is valid.
ALL STUFF is behind F5 which i have no access. But error can come from that side too.
And the TLS is not currently fully setup (have a tls for domain.com i “accept” the risk).
Setup conf file (apache and grafana)
  • What happened?
Currently not working.
    A working configuration.
Directory structure :
/var/www/sub/webroot
/var/www/sub/subpath2
The apache conf :
<VirtualHost *:80>
  ServerName sub.domain.com
  DocumentRoot /var/www/sub/webroot
  RewriteEngine On
  RewriteCond %{REQUEST_URI} !^/\.well\-known/acme\-challenge/
  RewriteRule ^(.*)$ https_://%{HTTP_HOST}$1 [R=301,L]
  # Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
  # error, crit, alert, emerg.
  # It is also possible to configure the loglevel for particular
  # modules, e.g.
  # LogLevel info ssl:warn
  LogLevel info
  ErrorLog ${APACHE_LOG_DIR}/error-sub.log
  CustomLog ${APACHE_LOG_DIR}/access-sub.log combined
</VirtualHost>
<VirtualHost *:443>
  Alias /subpath2 /var/www/sub/subpath2/
  <Directory /var/www/sub/subpath2/>
     Options Indexes FollowSymLinks MultiViews
     Require all granted
   </Directory>
   <location "/sub/subpath1/" >
     ProxyPreserveHost On
     ProxyPass "http_://127.0.0.1:3000/"
     ProxyPassReverse "http_://127.0.0.1:3000/"
     RewriteEngine on
     RewriteCond %{HTTP:Upgrade} websocket [NC]
     RewriteCond %{HTTP:Connection} upgrade [NC]
     RewriteRule ^/?(.*) "ws://127.0.0.1:3000/$1" [P,L]
   </location>
    ErrorLog ${APACHE_LOG_DIR}/error-sub-ssl.log
    CustomLog ${APACHE_LOG_DIR}/access-sub-ssl.log combined
</VirtualHost>
The relevant part of my grafana.ini
[server]
protocol = http
http_addr =
http_port = 3000
domain = sub.domain.com
enforce_domain = false
root_url = %(protocol)s://%(domain)s/subpath1
serve_from_sub_path = true
Only 404 error or wrong redirection apache2 side. but i probably miss something.
    Not remember exact url but mostly here and official documentation.
