Grafana 10.1.1 / Ubuntu 20.04 -
Server Grafana login through Apache reverse proxy -
Apache setup with basic /location and then proxypass:
Listening on $IP OF NAT and proxying internal Grafana instance
<Location /grafana> RewriteEngine on ProxyPass https://grafana-server:3000 ProxyPassReverse https://grafana-server:3000 </Location>
Following was tested with nginx and worked properly:
location /grafana {
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-Proto “https”;
proxy_pass https://grafana-server:3000;
Grafana.ini configured as follows:
protocol = https
The ip address to bind to, empty will bind to all interfaces
#http_addr =
The http port to use
http_port = 3000
The public facing domain name used to access grafana from a browser
domain = $IP of NAT
Redirect to correct domain if host header does not match domain
Prevents DNS rebinding attacks
enforce_domain = false
The full public facing url you use in browser, used for redirects and emails
If you use reverse proxy and sub path specify full url (with sub path)
#root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
root_url = https:/$IP OF NAT/grafanaServe Grafana from subpath specified in
root_urlsetting. By default it is set tofalsefor compatibility reasons.serve_from_sub_path = true
- What happened?
ERR_TOO_MANY_REDIRECTS
Get login prompt
- Can you copy/paste the configuration(s) that you are having problems with?
No, though part of this config worked awhile ago in another environment where I was reverse proxying grafana as well, however that environment wasn’t using an IP for the NAT but instead an actual DNS name
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Can’t get to UI
