Hey all, I have Grafana running on my server with ip 1.1.1.1 and port 3000. I have a url, test.graf.net, pointing to the ip. By setting up the Grafana config like this, I am able to successfully access Grafana through the browser:
# Protocol (http, https, socket)
protocol = https
# The ip address to bind to, empty will bind to all interfaces
http_addr = 1.1.1.1
# The http port to use
http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = test.graf
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
root_url = https://test.graf.net:3000
I was assuming with this redirect, I should be able to access the Grafana page by going to https://dash.organization.net/dash but this does not seem to be the case
*The IPs and URLs have been changed for the purpose of this post
Would you be able, please, to provide a section with Grafana proxy configuration via apache? Is it expected, that when you providing subpath (i.e. /grafana), static files still serves from the root /public, instead of /grafana/public?
my company has configured proxy in our LAN settings.
if i could send notification mails without proxy and connecting to my own internet source,
when i connect internet through proxy, I can’t send ratification mails. It stamps
