Hey guys,
Someone is using grafana with subpath?
Hey guys,
I’ve made this following changes:
domain = mydomain.com
root_url = http://mydomain.com/grafana/
serve_from_sub_path = true
But it is not working… I’m using Ubuntu 20.04 with Grafana 8.4.4.
I have used subpath and it is working fine for me.
in my config this is what i have set
domain = localhost
enforce_domain = false
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
what is the error you are getting ?
Thanks for your answer.
My goal is access my url like:
Without the 3000 port
Once I tried it I got the error:
The requested URL was not found on this server.
My config:
For anyone out there struggling with this.
server { etc... etc..
set $grafana_upstream "grafana";
location = /grafana {
return 301 /grafana/;
location /grafana/ {
limit_req zone=ui_rate burst=10 nodelay;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-Port 443;
proxy_read_timeout 90s;
proxy_redirect off;
proxy_pass http://$grafana_upstream:3000;
[server]
protocol = http
http_addr = 0.0.0.0
http_port = 3000
domain = <your_domain>
enforce_domain = true
root_url = %(protocol)s://%(domain)s/grafana/
router_logging = true
static_root_path = public
enable_gzip = false
read_timeout = 0
Grafana Documentation states it like this:
Note
You only need this if you don’t handle the sub path serving via your reverse proxy configuration.
If you don’t want or can’t use the reverse proxy to handle serving Grafana from a sub path, you can set the configuration variable server_from_sub_path to true.
root_url.serve_from_sub_path to true:Source: [Grafana Configure-nginx](https://grafana.com/tutorials/run-grafana-behind-a-proxy/#configure-nginx)
Some URI’s need connection upgrade: /grafana/api/live/
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $http_connection;
