Timezone Offset Issue in Grafana despite UTC Configuration
Hi everyone,
I’m visualizing data from a MySQL database in Grafana where timestamps are stored in UTC (+00:00). However, when I query the database, I see the data displayed with my local timezone (+1:00). The issue I’m facing is that even though I’ve configured Grafana to use the UTC timezone, the data is being displayed with a +1:00 offset, as if Grafana is performing an implicit conversion on the data.
Here’s the SQL query I am using:
SELECT
  energy_consumption.updated_at AS "time",
  device.nome AS "metric",
  energy_consumption.sensorData AS "value"
FROM
  energy_consumption, device
WHERE
  device.idDevice = energy_consumption.idDevice
ORDER BY
In Grafana, I have set the timezone to UTC, however, when I check the Query Inspector, I see that the timestamp is being retrieved with my local timezone (+1:00). This is because Grafana seems to be converting the data to my local timezone, even though the database stores it in UTC (+00:00).
Additionally, when I try to display data for the last 5 minutes, Grafana shows no data because it’s interpreting the timestamp as if it were in UTC, and there is no data within that time range based on the current local time.
It seems like Grafana might be performing an implicit timezone conversion on the data. Has anyone encountered this issue or knows how to fix it?
In Grafana settings I have already configured the axis and the time range in UTC format, because the datasource is in UTC format. This is the insert command that I use for the database:
f"INSERT INTO energy_consumption (updated_at, idDevice,  macAddress, sensorData) VALUES (FROM_UNIXTIME({timestamp}), '{device}','{macAddress}', {data})"
UTC format and actual UTC time zone are two different things
The datetime needs to be UTC time zone
Check out convert_tz function to set the data to UTC time zone
convert_tz(timestamp,'US/Eastern','UTC')
so
convert_tz(timestamp,'Your Time Zone','UTC')
Finally, I have found this solution that worked for me. Instead of taking directly the timestamp from the database, I convert it to UTC epoch time:
SELECT
  UNIX_TIMESTAMP(energy_consumption.updated_at) * 1000 AS "time",
FROM
WHERE
ORDER BY
  energy_consumption.updated_at;
