- The table has a lot of data. How do you get it to scroll
Welcome
The table plugin has a property where you can set to paginate
First of all, thank you very much for your reply. I used it for wheel casting, so it needs to scroll automatically instead of clicking. I didn’t see the paging property on the page, my version is Grafana v9.5.1 (bc353e4b2d)
Check this thread out for auto scrolling
I can’t change the code because it was deployed on the server by another colleague, so I see the page like this
You want it to scroll horizontal?
Also are you using ms sql server?
I want to scroll vertically
I’m using multiple data sources
