Vertical scroll in Grafana 7 tables
I have a table with many columns; not fit to screen size.
In order to get to the vertical scroll I have to first scroll horizontally to the last column, and only there I can see the vertical scroll. This is much less convenient then having the vertical scroll at the side all the time. It requires too many and unnecessary horizontal scrolls.
I’m using Grafana 7.0.3 on Chrome.
Scrolling using mouse wheel does work. But unfortunately this does not fit to all users. Some prefers the plain old vertical scroll.
It’s also related a bit to pagination; Will it be part of v7 tables?
Thank you,
Moshe
