Hi! My database query contains about 24 columns. Two of which are json structures, which also contain a lot of data. So I have a very long string.
Is it possible to display data in a vertical table in grafana? On the left is the name of the field, on the right is its value.
It was a feature request :
In the second link there is a workaround using CSS.
Hope it helps.
Good Luck
One thing that might suit your needs (although, it’s not exactly what you are looking for) is to display the data as a “Log” panel type instead of “Table” (At the top right in the picture below)
