Table panel does not show all rows
I’m using grafana 7.0.5 with Prometheus and Redis.
I have defined a table panel, but for some reason it doesn’t display all the rows it should display. When I do inspect->query, I see all the elements. When I do inspect->data, it doesn’t show all the data, but when I download the data as CSV, all the data is there.
The panel also does not have a vertical scroll bar and I don’t see where to add it.
Here is the json of the panel. I would appreciate any help. Thanks.
  "cacheTimeout": null,
  "fieldConfig": {
    "defaults": {
      "custom": {
        "align": "left",
        "displayMode": "color-background"
      "unit": "none",
      "thresholds": {
        "mode": "absolute",
        "steps": [
            "color": "green",
            "value": null
            "color": "red",
            "value": 1
      "mappings": [
          "id": 0,
          "op": "=",
          "text": "Active",
          "type": 1,
          "value": "0"
      "links": [
          "targetBlank": true,
          "title": "Go to ${__data.fields[0]} DB Dashboard ",
          "url": "/d/D_Dersdb-dashboard?orgId=1&refresh=10s&${__url_time_range}&var-cluster=${cluster}&var-bdb_name=${__data.fields[0]}\r\n"
      "nullValueMode": "connected"
    "overrides": [
        "matcher": {
          "id": "byName",
          "options": "Database Status"
        "properties": [
            "id": "custom.width",
            "value": 150
            "id": "custom.align",
            "value": "center"
  "gridPos": {
    "h": 6,
    "w": 7,
    "x": 3,
    "y": 1
  "id": 166,
  "interval": null,
  "links": [],
  "maxDataPoints": 100,
  "options": {
    "showHeader": true,
    "sortBy": []
  "pluginVersion": "7.0.5",
  "targets": [
      "expr": "count(bdb_up{cluster=\"$cluster\"}) by (bdb_name) - count(bdb_up{cluster=\"$cluster\",status=\"active\"}) by (bdb_name) ",
      "instant": true,
      "interval": "",
      "intervalFactor": 1,
      "legendFormat": "{{bdb_name}}",
      "refId": "A"
  "timeFrom": null,
  "timeShift": null,
  "title": "DBs Status",
  "transformations": [
      "id": "seriesToColumns",
      "options": {}
      "id": "reduce",
      "options": {
        "reducers": [
          "last"
      "id": "organize",
      "options": {
        "excludeByName": {},
        "indexByName": {},
        "renameByName": {
          "Field": "Database Name",
          "Last": "Database Status"
  "type": "table",
  "datasource": null
I know in Grafana v7 (at least the early versions, maybe still now) the new table panel vertical scrollbar could be hidden if the table had a horizontal scrollbar - e.g. you had to scroll the table all the way to the right to see the vertical scrollbar.
I think there is some limit on the new table panel, see here:
https://community.grafana.com/t/show-more-than-500-rows-in-grafana-table/27790/3
Or if the new table panel is no good for your needs you can continue to use the old (v6) table panel in v7. just change the panel JSON to “type”: “table-old”
