Show Table values horizontal
I have the following visualization:
Here is the code for one of this lines:
from(bucket: "mybucket")
  |> range(start: 2024-11-14T23:30:00Z, stop: now())
  |> filter(fn: (r) => r["topic"] == "***/devices/cubecell-board-3/up")
  |> filter(fn: (r) => r["_field"] == "uplink_message_decoded_payload_Batterie")
  |> filter(fn: (r) => r["_measurement"] == "thing_network")
  |> aggregateWindow(every: 1d, fn: mean, createEmpty: false)
  |> yield(name: "mean")
I would like to see in an additional visualization just the values in a table like this:
With the second visualization I will check faster different values over the days, also if the difference is minimal.
If I just change the visualization type to table it’s showing the values vertical:
Any idea how to solve that?
add transpose transformations.
But first you need to modify your date-time to DD-MM
Disco lights
