What Grafana version and what operating system are you using? v11.6.1 Windows
What are you trying to achieve? I’m trying to create a matrix-style visualization in Grafana where X axis represents the days and Y axis test case names and the cells represent the result of the test case during a specific time interval, with Green box for pass and Red for Fail
I am using prometheus as the datasource and the format of the data is below
test_case{name=“SSMPA-9000”,id=“3a157d8b-463a-9c82-e923-d1962d9b4ab4”,result=“fail”} 167.2132199 1742320541
test_case{name=“SSMPA-9003”,id=“3a157d8b-463a-9c82-e923-d1962d9b4ab4”,result=“pass”} 96.6563481 1742317479
Ideally i’m new to Grafana and i’m looking for ways to get this done. Which visualization to use and such.
What happened?
