Hello grafana community,
9.5.2
- What are you trying to achieve?
I want to display a time series based on a prometheus (promql) query.
Expr : sum by (path) (increase(http_client_responseTime_seconds_sum{path=~"/.*", path!="/_bulk",path!="/_node/metrics/prometheus",job="gravitee-gateway-préprod"}[1m])) != 0
- How are you trying to achieve it?
Pasting the query into the query tab on a time series visualization
- What happened?
No data is shown and the query inspector return 0 rows.
Showing the visualization of this query.
Prometheus return the correct result :
No error log on the grafana ui nor the browser console.
No particular error log on the prometheus nor grafana docker container.
- Did you follow any online instructions? If so, what is the URL?
No particular online instructions.
MY NOTE
I alreeady tried to delete the actual visualization and create a new one without success…
Time range on dashboard : last 6 hours.
Scraping inteval : 35 seconds
When changing Time range to Last 12 hours (or more), it does display graph !
Thank you for any help you could provide !
