Hello Grafana Community,
I’m currently facing an issue with a Prometheus query in Grafana and would appreciate any insights or suggestions.
I have a metric nginx_request_status_code_total
that tracks the number of requests with different status codes. When I query the metric without specifying a time range, I get results as expected. However, when I add a time range, such as [1h]
, [10m]
, or [15m]
, the query returns no data.
Here’s an example of the query that works without a time range:
sum(nginx_request_status_code_total{status_code="404"})
And here’s the query that does not return data when I add a time range:
sum(nginx_request_status_code_total{status_code="404"}[1h])
Things I’ve checked:
- Verified the metric name (
) and label (status_code="404"
) are correct. - Ensured Prometheus is scraping metrics and Grafana can access Prometheus data sources.
- Reviewed Prometheus logs for any errors or warnings.
Despite these checks, I’m unable to retrieve data when specifying a time range. Could anyone please advise on what might be causing this issue or suggest additional troubleshooting steps?
Thank you in advance for your help!
