I am using Amazon’s Managed Grafana, v9.4.7 -
I am trying to build a dashboard that displays a gauge of single metrics which are available through the Prometheus data source -
Building a dashboard panel -
What happened?
When I increase the timespan of the query, for some reason it excludes certain metrics. I am doing a SUM of this metric across the timespan. When I look at the last 6 hours, I can see the accurate count that I expect. However, when I look at the last 7 days, the number decreases by more than half. When I choose “This Month” for the timespan, it says No Data. Why would this be? Does it have to do with the interval? -
I expect the count that shows up to be at least greater than the last 6 hours for a larger timespan, since there are more metrics. -
No -
