v8.3.1 -
See below: have the footer calculate the Mean for one column and the Max for another
I haven’t found any documentation on this being possible. I’ve tried tweaking the panel settings to no avail. -
What happened?
I can at most have the Mean calculate only for 1 column or the Max only for another, but not one calculation for each. -
I expected to see a setting where one can define how to aggregate each column. -
Description above should be enough, otherwise let me know. -
No. -
No.
this isn’t possible as described, but you can add new fields from a calculation using transformations
But those fields are new columns by definition, never new rows, right?
that’s correct. Grafana’s data frame model is columnar oriented, not row oriented. I personally don’t know any way to add an extra row to the bottom of a table with pre-existing rows in grafana
Well, the “Show footer” option does add a row
But it’s not possible to have different calculations for different rows, I wonder if others wouldn’t find that useful too.
Totally…I have some columns that I would like to sum and others that I want a mean. Is sad that is not possible.
what is your data source?
It’s InfluxDB (v1 still)
