I am using Grafana 9.1.2 on RHEL 8.
On a dashboard I show multiple stat panels over a number of ‘environments’.
- 1 row repeating over a variable (values are to be determined at runtime)
- different stat panels with 1 query each.
If there are too many queries, the panel title does not contain all data because there are too many columns. Tooltips are a partial solution to overcome this.
In some installations the number of rows (environments) is very limited (2-3)
Is there an alternative “style” that one can use to transpose rows and columns? So some kind of table with
- one query per row
- First column can contain “the description of the query”’ (similar to the above panel title per query)
- And individual columns per “environment” value, showing the content for that value
Any idea is welcome,
Thanks,
Luc
