Common row for different columns
Hi I would like to know if the table panel can be used for a display like this
I would like to have the data centre in the left side column and the services running should be grouped as columns against these data centres. At the moment in multistat I can achieve this however the limitations are : 1. I am unable to show the required value that I want on top of the bar. 2. Each and every column has its own row header, instead I want the common row for all the columns.
So I tried to have a table view, however management doesnot want that. Instead they want for a particular data centre what are the applications that are deployed and its versions. Can you please guide me which panel type would be suitable for my requirement
