Stat panel on one row
Hi
I am struggling to get Stat panel repeated on one row only. Instead it is being split into two rows with 4 columns in each. What I want is a smaller panel just like on this page
I tried to adjust all the possible parameters to no avail. Is this at all possible? Even if I zoom out the whole page (CTRL+ -) it still shows 2x4 which in theory would have been auto resized and fit all in one row.
I am running Grafana 7.1.3
Did you set a value for the max per rowparameter?
If yes, try to set it to none
