I would like to see more even padding on single stat panels when the panel is shorter in height.
The panel is not designed to that smal (height wise)
Thanks for the reply.
There are two more smaller font sizes than what I’ve used. If the panel is not designed to be this small then what are this and the two smaller font sizes for?
I’ll add it to the repo as a feature request if that is the case.
